what do I call this?
Big Will
Member Posts: 395
There are four of them and two are leaking. 3" black iron pipe. Over 50 years old so great longevity. Dont know what to call it and neither does my vendor.
Pics????
Can we see this?0 -
got it
now you can see this
Dresser coupling
its a compression coupling for steel pipe0 -
Expansion Joint
Looks like a Steam Expansion joint. Is this on a steam or hot water riser?0 -
a cobb job is what I would call it.
looks like it has been leaking for awhile now. Dresser coupling would be what I would call it too. It may be there as an expansion joint. Looks like time to break out the gear reduction heads and thread some new pipe.Cost is what you spend , value is what you get.
cell # 413-841-6726
a cobb job?
Whatever it is, 50 yr. longevity is not too shabby!
Looks like the leaking is caused by the piping itself corroding on the outside.0 -
This is kinda funny
This fitting has no leak. The leaker is another riser room. I would like to know about the gear reduction head. I would have no choice but to thread in place. i have never seen a threader that would do that in such a tight spot. The two 3" lines are only about two inches apart. finally its hot water not steam. I brought the pic into the vender and he recognized it.0 -
Sorry with it being 3" I thought it was steam.
I would say with 2 inches clearance no getting to threader in there. I would say 6" minimum clearance. The dresser coupling should be fine to go and get a new one and cut back to the good pipe.Cost is what you spend , value is what you get.
cell # 413-841-6726
Victaulic
I'd look into using Victaulic couplings and hire a fire sprinkler contractor to do the work. They would need to cut out a 1-2 foot piece of pipe, cut-groove or roll-groove the two ends, fit a nipple in between and couple it together.
If the dresser coupling is intended as an expansion joint, then the nipple needs to be replaced by a grooved expansion piece which is made of braided stainless steel.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
