what do I call this?
Big Will
Big Will Member Posts: 395
There are four of them and two are leaking. 3" black iron pipe. Over 50 years old so great longevity. Dont know what to call it and neither does my vendor.
  • Pics????
    Can we see this?
  • Big Will
    pic
    I think I did it right this time
  • Big Will
    got it
    now you can see this ;)
  • TonyS
    TonyS Member Posts: 849
    Dresser coupling
    its a compression coupling for steel pipe
  • MikeyB
    MikeyB Member Posts: 696
    edited April 2010
    Expansion Joint
    Looks like a Steam Expansion joint. Is this on a steam or hot water riser?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,414
    a cobb job is what I would call it.
    looks like it has been leaking for awhile now. Dresser coupling would be what I would call it too. It may be there as an expansion joint. Looks like time to break out the gear reduction heads and thread some new pipe.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • a cobb job?
    Whatever it is, 50 yr. longevity is not too shabby!
    Looks like the leaking is caused by the piping itself corroding on the outside.
  • Big Will
    This is kinda funny
    This fitting has no leak. The leaker is another riser room. I would like to know about the gear reduction head. I would have no choice but to thread in place. i have never seen a threader that would do that in such a tight spot. The two 3" lines are only about two inches apart. finally its hot water not steam. I brought the pic into the vender and he recognized it.
    Sorry with it being 3" I thought it was steam.
    I would say with 2 inches clearance no getting to threader in there. I would say 6" minimum clearance. The dresser coupling should be fine to go and get a new one and cut back to the good pipe.
    cell # 413-841-6726
  • Victaulic
    I'd look into using Victaulic couplings and hire a fire sprinkler contractor to do the work.  They would need to cut out a 1-2 foot piece of pipe, cut-groove or roll-groove the two ends, fit a nipple in between and couple it together.
    If the dresser coupling is intended as an expansion joint, then the nipple needs to be replaced by a grooved expansion piece which is made of braided stainless steel.
