two pipe steam leak
Josh_15
Member Posts: 3
Question-
Sorry if this is stupid question, but we live in a 7 story building that has two pipe steam. We are on the 6th floor. One seam in the cast iron baseboard radiator has separated and is leaking. It's a small leak and I have a bowl underneath to catch the water and will have the plumber come out to fix it soon, but my question is this: The heat in the building has been off for well over a week since it's been warm in the 70's here. Why is there still small amounts of water leaking from the radiator? Again, sorry but it seems bizarre to me. Maybe it makes perfect sense, but any thoughts would be appreciated.
Thanks,
J
Thanks,
J
water leak
For some reason it takes forever for all the condensate to return. I have removed a steam boiler and returned days later to install the new one and the pipes are still dripping.0 -
The boiler may still be on.
The boiler may run for a domestic tankless heater. This would mean some vapor is always going up into the system even though it does not have enough heat in it to warm the baseboard it still travels with in the system.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
