Steam vacuum breakers
Anthony Menafro
Member Posts: 198
I have a customer that's having trouble with his Hoffman #62 vacuum breakers. They aren't stopping the boiler from going into a vacuum. I'm wondering if the #62's are not meant for this application. The boilers are 100hp running between 7 and 10 lbs. I would appreciate any input.
Thank you, Anthony Menafro
Steam boiler vacuum breaker
I have already told my customer to adjust the vacuum breaker from the factory set 2" down to 1".0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
