SF Intrepid with Indirect DHW?
jpf321
Member Posts: 1,568
After flopping back and forth between oil vs. gas .. and the MegaSteam vs. Intrepid .. an interesting point came up today .. can the SF Intrepid boiler be setup for indirect DHW? And if so, does anyone have any picture examples? I know that the MegaSteam is well designed for indirect .. but it doesn't seem to be the case with the Intrepid.
Thanks.
Thanks.
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
Yes it can
go here: http://www.slantfin.com/documents/172.pdf
On page 2, tapping #15 is labeled "3/4-inch zone tapping". That's where you'd hook up your indirect supply. The return line from the indirect comes into the main return tapping.All Steamed Up, Inc.
Consulting0 -
thanks
i did see that earlier, but wasn't sure if 3/4" was adequate ..1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
Depends on the indirect
you'd simply choose one with 3/4" boiler connections, such as an Amtrol or Burnham unit. S/F's indirect has 1" connections.All Steamed Up, Inc.
Consulting0 -
Related question for Steamhead
With the new boiler (SF,etc) and indirect set-up: If you were to use this for a replacement system in and old (1923) single pipe system, what protection/procedures would you follow to clean up the pipe system to prevent old gunk from infecting the new components? My worry is that the gunk in my wet returns would quickly waste a pump for the indirect and fill the indirect tank similarly.
Thanks0 -
Flush out as much of the piping as you can
and use a 3-piece bronze circ which will handle some gunk. Two popular ones are the B&G 100AB and the Taco 110B.All Steamed Up, Inc.
Consulting0 -
Thanks...
Good Info. Dave Stroman will be doing the work (though he doesn't know when, we talked a bit about future replacement a while back), so I'm sure he would recommend the same thing. I just like to be informed.0
