Cooling thru radiant tubing
Any body had any experiance with geothermal cooling thru radiant tubing?I got a phone call today from a company in Pennsylvania looking for a contractor to install ceiling radiant heat thru panels and pex tube(which I have done) and do the cooling thru the same tubing(installed in the ceiling) which I have not done.He says they can control the humidity so there is no sweating. Any comments or suggestions? can it be feasibly done?
Steven G.
  • zacmobile
    zacmobile Member Posts: 209
    cooling design
    I'm pretty sure Uponor had some design info on this, there are a bunch of documents on this subject in the Resources > Green tab on this site.
