Cooling thru radiant tubing
Steven Gronski
Member Posts: 98
Any body had any experiance with geothermal cooling thru radiant tubing?I got a phone call today from a company in Pennsylvania looking for a contractor to install ceiling radiant heat thru panels and pex tube(which I have done) and do the cooling thru the same tubing(installed in the ceiling) which I have not done.He says they can control the humidity so there is no sweating. Any comments or suggestions? can it be feasibly done?
Steven G.
Steven G.
cooling design
I'm pretty sure Uponor had some design info on this, there are a bunch of documents on this subject in the Resources > Green tab on this site.0
- 81.2K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 37 Biomass
- 394 Carbon Monoxide Awareness
- 2.7K Controls
- 1.4K Domestic Hot Water
- 3.8K Gas Heating
- 101 Geothermal
- 133 Indoor-Air Quality
- 2.4K Oil Heating
- 32 Pipe Deterioration
- 580 Plumbing
- 4.3K Radiant Heating
- 334 Solar
- 12.3K Strictly Steam
- 38 Water Quality
- 11 Industry Classes
- 52 Job Opportunities
- 8 Recall Announcements
