3 1/2 black pipe fittings
caustin
Member Posts: 3
I am replacing a huge boiler on Monday because its cracked and found out today that the 2 supply pipes are 3 1/2 black pipe not 3 inch like I thought. Now I can not find any fittings to reduce it down to 2 inch to run back to the boiler any suggestions.And yes they are 3 1/2 pipes.
re
im not sure where ur from but did u try met pipe? or watertown plumbing supply?
metro pipe 617 492 6400 watertown plumbing supply 617 924 28400 -
Break out the welder....
A 4" by 2" Weld Bend reducer with a 2" threaded by blank cut nipple ought to do the trick.
That or check with Starbuck. He might have a 3-1/2" X something laying around.
ME0 -
3.5
That might be a tough find, especially on a weekend. I looked on a couple of web sites for 3 1/2" fittings, no luck. Any Old Timers in your neighborhood w/some old ftgs laying around their shop? Might be worth asking.0 -
Once in a while
we get these at Pratt Thompson, in Baltimore. SAratoga-7-6826 is their number, and we're always finding stuff there that dates back to the phone-exchange-name days. Oh yeah, the area code is 410.All Steamed Up, Inc.
Consulting0 -
car ride
i think i will jump in my model t and head on over to pick it up thanks for the info0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
