cutting copper tubing with shears
shawn laverty
Member Posts: 42
Does anybody know if there are shears that can cut copper pipe quickly.
Milwaukee
makes a 12 volt tube cutter. I have been using one for over a year now. It is one of the best innovations in copper in a long time. Love it.0 -
Thanks for the tip TonyS,,
I didn`t know such a tool exists,,, ordered-one today! :-)0 -
Dave... just watch
when you cut overhead pipes filled with water. You can flood the electronics. I did this once and it took a day for it to dry out. I had to pipe the boiler in with a hand cutter... it was horrible LOL0 -
Nice tool
But the movie clip on Youtube pits the tool against a minicutter. Minicutters are slow; why not put it up (legitimately) against a regular tubing cutter? Kind of lame.
http://www.youtube.com/watch?v=UvIHQxqJBC48.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Your right
that is a lame video. I have found that it is important to keep the unit lubricated with wd 40 or equivalent. Dont bother trying to use it on egged soft tubing and it takes a little getting used to as any tool. It cuts tubing as close as 1 inch from a wall. I had a job to replace a bunch of old copper fin with new, it paid for itself with one job. It cuts from 3/8 to 1 inch tube.0 -
What the hey Alan,,,
I spend more than this tool cost on cigarettes per month,,,,
The Milwaukee video looks impressive, and TonyS speaks highly of-it,,, so I`ll give-one a try.
PS- I worked for a guy once who would try NOTHING new,,, we worked with the "Flintstones" tools,,, didn`t even believe in a 300 power-drive, everything by hand!
Lost many a job because he wouldn`t try something different. :-)0 -
Got mine today TonyS,,,,
Seems quite impressive after screwing around with-it!
I`ll be careful of the "water problem" you had,
Thanks ;-)0 -
Dave
they work great for cutting up your scrap copper into number 1 and 2 for the junk yard. Its alot easier to make those cuts on the little pieces you would have normally thrown in the #2 pile. Take care0
- 120 Geothermal
