Radiator Top not getting hot
marie14
Member Posts: 3
in Oil Heating
Old oil furnace. First floor radiators work perfectly. When get up to 2nd floor - each bedroom has a radiator, but only the bottom of them are getting hot. I've bleed the several times, still no luck. Is there some type of adjustment needed to make on the actual unit in the basement?
top of rads not getting hot
Marie: with an old "beast" like that boiler, I would suggest you contact a heating professional. It may be pressure related or another issue. Best to have someone look at it. Old equipment does not always respond like we might advise and trouble could be waiting at the turn of a screw.
AL0 -
Bleeding
When you bleed the radiators , do you end up with water ? If not , you don't have enough system water pressure...i cant read the gaugeThere was an error rendering this rich post.
Yes - I always get water out when it bleeds.0 -
top not hot
Is it a gravity system or do you have a circulator pump?0 -
Can we get a couple more pictures?
one of the side of the boiler and maybe one of from a bit farther back? Are the valves open at the radiators? A picture of them would be good also. There is the find a pro section at the top of the page. Some of us do work on all types of boilers not just steamCost is what you spend , value is what you get.
cell # 413-841-6726
Radiators.
Are the supply and return lines both on the bottom of the radiators? Is there a pressure gauge on the boiler (if you can trust it to be accurate)? What does it read?0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
