hotwaterheat
connie
connie Member Posts: 2
what is the flow rate for half inch pex when applied to a conventional boiler with convectors
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    It depends....
    on NUMEROUS variables, like pump size and pipe length.
    A general guide is to limit the flow in a 1/2" pipe to less than 2 GPM, preferably more like 1.5 GPM.
    At a 20 degree F differential in temperature, that flow would deliver 15,000 btuH to a properly sized heat emitter.
    ME
