Legend 1" Valve question
Maine Vent
Member Posts: 130
Can someone tell the reducing bushing size that will fit into where the valve stem would go? I went to fw webb they said it wasn't a 1.5" or a 1.25". I want to add a vent to the top of this valve.
Thanks for your help
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
not that type of thread
It does not line up with pipe thread. you can thread and tap the radiator if you are careful there should be another spot opposite the current vent. have you tried a larger vent on the radiator?Cost is what you spend , value is what you get.
cell # 413-841-6726
extra venting for riser
why not put a gorton "d" on the radiator in the usual vent tapping? the capacity is the same as a gorton #1 on a riser.
the valve bonnet threads are not tapered like regular pipe threads, so no joy there.---nbc0 -
Drill and Tap Size??
Thanks Charlie & nbc, can either one of you tell me drill size and tap size for 1/8" groton air vent?Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal0 -
Drill & Tap size
I see grotons come 1/8" or 1/4" for the 4,5,6,D models, can someone update my previous thread to these drill and tap sizes. I have vari vents now which i think are 1/8". do you measure the inside diameter of the vent hole itself?
Thank YouWeil McLean SGO4, Riello Gas Burner
404 sq ft EDR
extra venting
just put the gorton on in place of the old vent, and see if there is improvement.--nbc0 -
Easier Fix
Thanks nbc, your right, a larger vent is easier to install than drill and tapping steel.Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
- 50 Industry Classes
