have Richardson 2 pipe
bob1000
Member Posts: 2
What to know about air vents locat on return one is frozen can't move adjusting screw. What type of air vent can replace the richardson vents.
thanks
ira 516-569-0569
thanks
ira 516-569-0569
Get a Steam Pro
You might want to take a look in the "Find A Professional" section at the top of this page.
Scroll past the "zipcode" section (the sofware is new and "buggy") and scroll down to the "States" section . There are a couple of really good steam pros located near you. I'd get one of them to take a look at your system and give it a "tune up"
- Rod0 -
Yes
That sounds like a good idea. Is this the original Richardson vent? Kind of looks like a Tee? Didn't know it had adjustments on it.
A properly vented Richardson should have vents at the ends of the mains and the returns. Originally it just had the Return vent which was fine for coal firing.
The vents need to be sized for the size piping you have. Check out Dan's book if you have yet. Loads of great info.
http://www.heatinghelp.com/products/Books/5/68/Lost-Art-Of-Steam-Heating0
