Can I Use?
Went to an auction on Sat.  and bought 5Lb of  40/60 rosin core solder for a$1.00.  Can I use this for sweating copper pipe if I use regular flux.
Thanks
  • bob_46
    bob_46 Member Posts: 813
    Curious
    Hi Rich, just curious , how much do you think a leak is worth?
  • Rich Davis_2
    Rich Davis_2 Member Posts: 121
    thats what I'm trying to find out
    Should I use it or not?
  • Chris S
    Chris S Member Posts: 176
    5 mile solder
    We call that 5 mile solder.  When we ran out, and didn't even have an emergency roll,  but were only 4 miles from home,  used it on heat.
    Then we put a roll of emergency solder on each truck, so it wouldn't happen again.
    Oh,  it's still holding ( 10 years)
    hot_rod Member Posts: 26,580
    only in a bind
    I'd worry about puddles of the rosin in the bond? Save it for electrical work.
    I have used rosin core on some of my copper art projects. The thin diameter allows a tight, clean joint.
    hr
