Can I Use?
Rich Davis_2
Member Posts: 121
Went to an auction on Sat. and bought 5Lb of 40/60 rosin core solder for a$1.00. Can I use this for sweating copper pipe if I use regular flux.
Thanks
Thanks
Curious
Hi Rich, just curious , how much do you think a leak is worth?There was an error rendering this rich post.
thats what I'm trying to find out
Should I use it or not?0 -
5 mile solder
We call that 5 mile solder. When we ran out, and didn't even have an emergency roll, but were only 4 miles from home, used it on heat.
Then we put a roll of emergency solder on each truck, so it wouldn't happen again.
Oh, it's still holding ( 10 years)0 -
only in a bind
I'd worry about puddles of the rosin in the bond? Save it for electrical work.
I have used rosin core on some of my copper art projects. The thin diameter allows a tight, clean joint.
hrBob "hot rod" Rohr
Living the hydronic dream0
