Oh man,, long banks of CIBB on steam,,
Try to stop hammering,,,, sheesh!
Some banks are 26ft.(installed in 60`s),,, had to hammer from the get-go,,, std. 3/4" outlets using regular bushings to 1/2" Velan bi-metallic traps(<a href="http://www.velan.com/velan/en/products/22/26/?product_id=73">http://www.velan.com/velan/en/products/22/26/?product_id=73</a>) the "adjustment" within the trap helped, but not much as the condensate went over & under,,,, what a chore!
No room,,, so I removed every "check-ball", drilled the casting straight-through, and used orifice plates on the top supply(I made) to govern the steam admittance,,, everything came-out OK,, but experimentation involved as some rads had "sagged" over the years.
Frederic Tudor
would be proud of you!All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
