knight/ramp up ramp down
rocksolid
Member Posts: 1
hello, i have a lochinvar knight, i would like to use the ramp up ramp down feature, but do not have the pc to interface it, i have had it set in the past where it was running like a ferrari, at about 30-33% rather than ramping up to 100% meeting the set point then shutting off (i guess short cycling), do i need the pc interface, or do i just need to know the proper settings for the boost temp/ cycle time..etc etc.. any ideas?
thanks in advance
thanks in advance
Pretty sure...
That is one of the parameters that has to be accessed thru the lap top.
Alledgedly soon to change, but not without firmware upgrades.
ME0 -
dude
I'm curious though,
you say," i have had it set in the past where it was running like a ferrari, at about 30-33%"
and that statement gives me pause to your familiarity with the nuances of this unit. Are you a contractor or homeowner? and what is your knowledge base of this unit?
When their is a "call for heat" it's only focus is to meet setpoint and hold that temp until the "call for heat" is satisfied no matter if it is firing 20%-100%. If your setpoint temp is programmed right, either fixed or using outdoor reset (self-adjusting), it shouldn't short cycle.
If it is short-cycling maybe your setpoint is too high? Are you using outdoor reset? If you are, what are your F1-F9 settings?
If not short-cycling, what is the complaint?0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
