checking pump sizing
RJ_4
Member Posts: 484
I Inherited a bldg with rad floor heating (PEX Tubing) any one know of any pipe T.E.L. sizing charts that I could use to to verify If my ft/head at my pump is adequate. There are no mech prints. I have 27 rooms, dont knowhow much tubing is under floor.
If You Don't Know
The foot of tubing or heat loss how would you size a pump? There is no magic chart. What seems to be the problem that you are experiencing to make you think there is a problem?There was an error rendering this rich post.
no flow
I have no flow on part of 2nd floor, bled out air no changeThere was an error rendering this rich post.
Just Happened
Did this just happen or has it always been an issue?There was an error rendering this rich post.
pump sizing
Suspect this problem on 2nd floor has always been there, the bldg goes through 1 mtc. man a year. No past record keeping. Have found some good info through watts , taco and Cal Steam, today. thanks all !There was an error rendering this rich post.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
