New Rinnai Condensing as back-up for off-peak system
EricAune
Member Posts: 432
Here are some pics from a system I just started this last week. Its has electric as the main heat source and new Rinnai (LP) condensing unit for back-up and DHW. This is a lake home in north central MN.
The owner installed the tubing in the basement and garage slabs, I will be doing the staple-up for the main level and climate panel for the loft and bonus over garage later this spring. We will be adding an array of SolarSkies collectors with a pressurized drainback system this summer.
This is also one of the new Marathon thermal storage tanks, haven't used one yet. Utilizing the iSeries mixing valve (odr) out of the tank for reset. Setting the Thermolec at 160*F (twenty-five over design) with no outdoor sensor, the Rinnai will utilize odr as it is a back-up and will benefit at lower temps.
Interested in
how the set-up on the Rinnai has gone for you. Many programming options. Are you using the concentric poly-prop vent?0 -
Yet to set-up
Haven't done the set-up yet, this job is about two hours north of me so it will be a drawn out project. Its for a lake home that has been under construction for about a year already. Should be another week or so.
The venting will be two pipe solid core PVC. Still not a fan of the manufactures vent system. I have had some issues with the inner exhaust tube (fitment & coming loose). Also not a fan of the pricing.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
