U - Tube Manometer
Positive Solution
Member Posts: 21
in Gas Heating
I am looking for a U-Tube manometer. The catch is that I want the simple water tube manometer - not the one with the red or blue or green dye. All you do is put some water in the tube, hook up to the gas line and you get your readings. You never have to worry about dye leaking out or anything like that.
I can't find it anywhere. Anyone know where I can find one or is anyone interested in making a sale to me?
U tube
You can get a Bacharach or Dwyer U tube gauge at most supply.
[url=http://www.bacharach-inc.com/pressure-gauge.htm]http://www.bacharach-inc.com/pressure-gauge.htm
You don't have to put the dye but it does help to see.0 -
Go with Dwyer U tube it is
less expensive.
Do not use anything other than water in the tube as coloring and other chemicals change the viscosity of the water and affects the accuracy of the readings. I have actually run lab experiments to prove this. WATER ONLY!0 -
Correct Tim....
Since the red water, (oil mix) does have a different viscosity. UEI, makes a differential meter for some bucks that can measure neg, pos, or diff pressures. I use mine for pressure switches and the like. For Large Air Rotation units, when measuring diff. across burners or static pressure, It's too sensitive and bounces way too much. Inclined withe the so called RED stuff...:-) works great.
PS How are things Tim Mc.
Peace
Mike T.0 -
Mike I am doing great
thanks for your input hope you are well.0
