Radiant windows
TonyS
TonyS Member Posts: 849
Mark, just checking to see if you had time to sort out the info you took on those radiant windows a few weeks ago?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    Thanks for asking...
    I learned something that weekend. I was attempting to use a device called a flux sensor. Not the kind you solder with, but rather a thin film sensor that can tell you how many BUTH the surface it is connected to is conducting, and what direction is it flowing in. Early on I discovered that if the sensor is not held REAL tight to the surface (it is about 1.5" X 1.5" square) it gives false readings. So, in order for it to work correctly, it MUST be thoroughly and completely bonded to the surface to which it is attempting to monitor. I was simply using reinforced shipping tape with real sticky adhesive. Not good enough.
    I also discovered that the adhesive on the tape doesn't work real well at zero degrees F. outside temperatures.
    So, I am going to have to purchase numerous of the thin film sensors (at around $350.00 each) and adhese them to the exterior of the windows with some 3-M spray on adhesive, and try it all over again.
    The best laid plans of mice and men....
    But thanks for checking in just the same.
    ME
  • TonyS
    OK we will give you one more week
    LOL. WOW at 350 apiece we could be waiting awhile. Keep us informed even if its not real scientific I would like to know the amp draw per square foot of glass during several different outside temps.
