BTU of cast iron rad.
Steve Whitbeck
Member Posts: 669
Customer wants to replace this rad. with cast iron baseboard but I can't find what the output is for this one.
It is a cast iron box that looks something like a normal radiator but it is hollow and on the inside about a third of the way up there is a cast iron ( fin tube ) that goes from end to end. This is not a sectional rad.
It is 18 inches high, 9 inches deep, and 41 1/2 inches long.
Anybody know what this thing will put out???
Weil Mclain
Sounds like a Weil Mclain ...do you have a photoThere was an error rendering this rich post.
NO photo
I looked at the Weil McLain rads and didn't see one with the same dimensions.
I found one that looked something like it.
It has a cast iron fin tube inside the cast iron box.0 -
Man that could be anything,,,,,,
without a pic,,, is it a convector?,,,, oh we may stumble on-it, but more info is needed to be precise.0 -
Educated Guess
Sometimes You have to make a educated guess .. I seen that style once or maybe twice. The Wild Mc had a clip in cast door to gain access to a vent or bleeder. I believe the the only water or steam cavity was in that inside hunk of fin cast .. I would look for a compraple lengh , figure the difference of listed EDR heights to come up a percentage of out put .. Then adjust to your size ..There was an error rendering this rich post.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
