Need Steam boier in Dumont NJ
JerseyWreckDiver
Member Posts: 14
I'm trying to find a good craftsman to replace a steam boiler in Dumont NJ - a little North/east of Paramus and the find a professional feature doesn't seam to be working...
Dumont Steam
Contact Information
David & John Cataneo NJplumber@hotmail.com Phone 973-672-1000
Scroll down the FAP page and you'll find a list of states. There are only four heating companies listed in N.J. C'mon the rest of you Joisey pipe jockeys, sign-up! What? you hate money?0 -
No go
Yah, I already called them, apparently a 1/2 hour drive from the office is too far for them. Thanks anyway.There was an error rendering this rich post.
Dumont Steam
I guess those guys hate money too. Well your alternative is to contact heating contractors close to you and ask questions about how they will install the boiler.
I went through this with my sister who needed a new steam boiler. To weed out the true knuckle-heads you start by asking two basic questions:
1) How will you size the new boiler? The only good answer is by the size and number of radiators.
2) How will you pipe the new boiler? Answer: Black pipe and per the manufacturers' specifications.
Any other answers are a no-go. Period.0 -
good luck dude
I know you may be in for a hard hunt ,i have taken a look at a couple of steam jobs in your town and most where not piped correctly and maybe the price they paid for the job had some thing to do with it about 1/2 on my price ,i had given them prices to re piping and they complained and stated it was to much money so there steamboiler still work like $rap ,stick to your guns on the steel pipe and exeeding the manafatures header diagrams as for sizing good luck not many will check your rads or edr and even better luck on a heat lose or heat what ,I can not reccomend any one for i know they all hardly ever pipe any thing larger then 2 inch,be carefull lots of hacks in sheeps clothing peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Band Aid Applied
I asked my inlaws if anyone looked at any radiators... no to all, nobody went outside the basement. They all said they would pipe it up real nice in copper.... Like a parade of clowns. Never fails in the middle of Winter.. I couldn't take it anymore and drove out there today. I warned him about the Copper header 10 years ago when I first saw it, but i was still surprised today at the level of corrosion for an 18 year old peerless.
Anyway, I patched the hole pretty well, I'm confident it will hold until spring when I can take my time finding the right contractor or break down and do it myself.
The pics show the rot and the fix. The head of the 3/8th bolt and another 1" washer are inside the water chamber with a good helping of steel impregnated epoxy between the washers and the cast iron, everything sinched up tight and hardened off, it was holding fine when I left...There was an error rendering this rich post.
Co dect.
Holes like that in a boiler is not a good thing and i am surprised if any heating expert would leave that unit on line ,be sure your in laws have a CO dect in the bed room and one some where near the boiler like bottom of the basement stairs ,with a hole like that steam escapes in the chimmey and effects the draft some times and an cause combustion gases to esape in the home and as stated CO effects the very old and very young in this sitiutation i think it is dangerous and if some thing where to happen i know if it where me i would feel responablle .This is not to bash your repair very cleaver but i know it is not what i would do for my parents or in laws ,friends or a custormer but heck that's me and after just 1 brush with CO and it;s dangers i never have to be told twice peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
