Outdoor reset control.
chuck172
Member Posts: 90
I'm looking for a simple, economical, outdoor reset control.
I need it to vary the load circulating pump speed to throttle my boiler water temperature.
What's available ?
What's available ?
Your asking for Two
Seperate things. I'm going to assume your system is zoned with zone valves based on your question of only wanting to control 1 pump and I am going to assume you have a conventional cast iron boiler.
Control the zones via a Taco EXP zone control. Add the PC-700 outdoor-rest card. Change the system pump to a Grundfoss Alpha. Now you have out-door reset and circulator modulation...There was an error rendering this rich post.
Reset Question
Another option would be to use the Honeywell AQ2000 which is very easy to set up and has many simple to use features. One of the features I am using is the "data log" which tells me how long each zone has been calling. The model to look at for one temp reset is the AQ25142B2.0 -
Also take a look at Tekmar
I installed a Tekmar in my house about three years ago with out a lot of fuss and it has saved me a lot.0 -
tekmar?
Which tekmar control did you get?0 -
D356
I have the D356 picked it up from Sid Harveys.0 -
You may want to look at
Model A265 download there pdf I am guessing we are talking about a small residential system.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
