cold cellar
Rick_41
Member Posts: 67
Ok now that I have wrapped all my pipes really well, my cellar is really cold. Its unfinshed but I like to be down there to do bench work etc. I have previously put up 4' 1 1/2 duct insulation with reflective surface and it has made the cellar warmer and much brighter and has stopped some inflitration (sheet plastic on walls first)
But I was wondering if I could place a small fan to blow across the 6 foot of vent pipe (the draft temp is over 500 degrees) to take out some of the stack heat before it goes out the chimney. I doubt it will drop the exhaust temp so much that chimney condensation would be a problem.
But could I splice the fan motor to come on when the burner fires w/o problem? As small fans don't draw many amps.
If the air is blown from the back, would this effect the baro damper?(the air hitting the back of the damper)
I Remember Those ...
...They use to make them years ago ...or right after oil hit $1 a gallon ... They were a box with small horizontal tubes running across the flue passage . A fan forced air through the tubes .. They also had a plate with a rod and handle that scraped the tubes clean ...There was an error rendering this rich post.
Magic Heat
They still make and sell them!
http://www.amazon.com/Magic-Heat-Reclaimer-Wood-Stove/dp/B0000AXEXE0 -
There You Go...........
.......There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
