Venting the header
Luv'nsteam
Member Posts: 278
Is it advantageous to vent the header?
Thank you,
Mike Mumma
Thank you,
Mike Mumma
venting header
Rarely done unless thru a steam trap as a drip on a large header. Usually the end of the main vents will get the steam out there if properly sized and working. What size of header are we talking?
I see not reason to vent a residential header if the near boiler piping is done correctly.0 -
vented header
That is what I thought, but I decided to ask. My header mock-up is posted in strictly steam if care to have a look at it.
http://www.heatinghelp.com/forum-thread/129407/DROP-HEADER-MOCK-UP
Thank you,
Mike0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
