Innovative or stupid? You tell me
A customer has really poor access to the steam traps. It's the typical story of a carpenter and a tile man not respecting what he is covering up. In the bathroom radiator, the steam trap has been boxed in so that there is no enough access to remove the trap with out doing some "surgery" on the customer's finish work. The customer is reluctant to allow that. The steam trap appears to be stuck open. What if I were to remove the element and shoved a rag in the trap? Then it would effectively be stuck closed, which would be better because it would keep steam out of the return pipes and thus not interfere with proper steam function of other radiators. Probably some air and condensate would make its way past the rag, which might allow some heat from the radiator. That could be good.
If that radiator is not an important one and the heat won't be missed, isn't this a good trade off to keep steam out of the return piping? Is there a downside to doing this?
