Multiple kind of main air vents
andyz
Member Posts: 18
I have a 2 pipe gravity return system, (no radiator vents) there a two long mains which come to an end on the far side of the basement and drop down into a hartford loop or at least a wet return. At the end of the mains are air valves. One was a Dole Quick Vent #5 and the other a Dole Model 90.(above the boiler on the return is also a Hoffman Main Vent Valve #75).The Dole #90 recently failed and was replaced with a simple Dole #4.Question: should these 2 end of main vents be the same, is the Dole#4 OK, the old Dole you could hear sucking in air when the boiler cycled off, but these 2 are now silent. The Main#75 vents when the boiler fires, every thing works fine, just wondered what the difference is?
was going to...
i was going to recommend that you get Mr. Gills book http://www.heatinghelp.com/products/Books/5/146/Balancing-Steam-Systems-Using-a-Vent-Capacity-Chart-by-Gerry-Gill-and-Steve-Pajek .. but in looking at it, I see that it doesn't list the capacities for all the vents you mention .. it only has Dole #5 and Hoffman #75.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
There's no harm to mixing
vent sizes or makes. And if everything is working... "if it ain't broke...!"Br. Jamie, osb
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
