internal wrench
Brian_74
Member Posts: 237
To remove and to install a steam trap union nut nipple am I right in thinking that I'll need an internal pipe wrench? If I do, any opinions about which style is the best?
The third one is the kind I use
The middle is used for toilets and urinal spuds, and the first is used for small pipe nipples. Like Shower head arms.Cost is what you spend , value is what you get.
cell # 413-841-6726
For once I don't need the most expensive tool!
Thanks, Charlie, for clarifying which is which. I do need one for trap installation and removal, then, don't I?There was an error rendering this rich post.
