Removing a radiator
Chris_92
Chris_92 Member Posts: 6
Hello,
I am doing some remodeling in my upstairs bathroom. I need to remove one of my 1950's or so vintage radiators (burnham cast iron slender series), I have a 2 pipe system, hot water, but only 1 valve (manual control valve, no lock valve) on the one side. The other side is simply a 90 elbow going back thru the floor.
How do I remove this radiator without draining the entire system? Can I just put a cap on the pipe for the few weeks I will be renovating and continue to use the system?
Thanks
    Steamhead Member Posts: 18,205
    You will have to drain the system
    below the second floor to disconnect that radiator. Then you will have to refill it after capping the lines. The same procedure applies when you put it back in.
    Consulting
  • Chris_92
    thx
    thanks steamhead, I'll give it a go tommorow
