Had to bang of LWCO for Burner to start
Sly
Member Posts: 29
My burner would not fire at all. It went straight to lockout. When I banged on the LWCO it fired right away. Has this happened to anyone before? Does it mean it might be faulty?
Type of LWCO?
If it's a probe type, you may have a loose connection. Or the probe could be grubby. If it's a float type, how long has it been since it's been flushed out? Or the float could be sticking?
Or... it could just be faulty!Br. Jamie, osb
LWCO
I have never flushed it out. How do you do that?
Thanks
silvion0 -
LWCO
What kind do you have? If you don't know the model number, send us a picture.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 117 Geothermal
