boiler feed pump
RJ_4
Member Posts: 484
Equipment: Peerless 211A-07 boiler
Hoffman Duplex feed pump, McDonald Miller l.w.c.o./pump control
I have a one pipe steam system with the return header in the boiler room above the boiler water line with a master f & t trap. The problem is, the boiler runs for awhile, the pump control activates the feed pump and sometimes the low water cutoff part of the controller shuts off the burners. I have tried different settings of the circuit setters on the pump outlets. Still having problems.
Also, due to improper header piping, gas pressure has to be set low to keep from entraining water up thru steam header.
responses
I may have written my post incorrectly several days ago, I was hoping to get help with a boiler feed pump problem RJ.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
