Taco 571-2 Zone Valave Question
I have a Taco 571-2 Zone valve that seems to be stuck.  If I switch it to manual, I get heat.  IS it possibly just the head??  It is hot to the touch, but no water circulating
  • Check for voltage
    If you've got 24 volts to the powerhead and the valve is not open, replace it.
    If it's hot, that can be a sign of a faulty head.
