Taco 571-2 Zone Valave Question
bisquits1
Member Posts: 7
I have a Taco 571-2 Zone valve that seems to be stuck. If I switch it to manual, I get heat. IS it possibly just the head?? It is hot to the touch, but no water circulating
Check for voltage
If you've got 24 volts to the powerhead and the valve is not open, replace it.
If it's hot, that can be a sign of a faulty head.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
