Cast Iron Radiator
AHerra
Member Posts: 15
I am in the Chicago area and I am looking for a used cast iron radiator. As this point I can use just about anything. currenty there is a 22"Tallx14"Wx8'L radiator in the room. I can also repipe it a little bit and use a 36"-42" Tall x 10-14Wx 36"-48"L radiator. I had saved dozens of radiators over the years and one day I came to the shop and someone took them all. If anyone has something laying around let me know.
Thanks,
AL Herra
Thanks,
AL Herra
Why not,
just get one closer to you?
You could use one the same size as you had, or larger, then put a TRV on that-one.
Once you find the temp setting on the TRV(regardless of where the stat is), you should be comfortable.0 -
New Radiator
I still need a new radiator. The old one is broken due to foreclosure. Can anyone help with a new old radiator.0 -
Have you tried
Consumer Plumbing in "Chicagoland"? It's one of the sources on Dan's radiator list. Go here:
http://www.consumersplumbing.com/
I have a bunch, but the freight charges from Baltimore would be rather high......All Steamed Up, Inc.
Consulting0
