Cast Iron Radiator
AHerra
AHerra Member Posts: 15
I am in the Chicago area and I am looking for a used cast iron radiator. As this point I can use just about anything. currenty there is a 22"Tallx14"Wx8'L radiator in the room. I can also repipe it a little bit and use a 36"-42" Tall x 10-14Wx 36"-48"L radiator. I had saved dozens of radiators over the years and one day I came to the shop and someone took them all. If anyone has something laying around let me know.
Thanks,
AL Herra
  • Why not,
    just get one closer to you?
    You could use one the same size as you had, or larger, then put a TRV on that-one.
    Once you find the temp setting on the TRV(regardless of where the stat is), you should be comfortable.
  • AHerra
    New Radiator
    I still need a new radiator. The old one is broken due to foreclosure. Can anyone help with a new old radiator.
    Steamhead Member Posts: 18,209
    Have you tried
    Consumer Plumbing in "Chicagoland"? It's one of the sources on Dan's radiator list. Go here:
    http://www.consumersplumbing.com/
    I have a bunch, but the freight charges from Baltimore would be rather high......
    Consulting
