visited Slant/Fin today ...
jpf321
Member Posts: 1,568
So since I was in the neighborhood .. I dropped by the Slant/Fin plant in Greenvale, NY today .. needless to say they were a little caught off guard by a home-owner dropping by... anyway, since I'm shopping around for a replacement for my Fitzgibbons 402 .. and steamhead and charlie in wmass recommended Slant/Fin .. i figured i'd investigate ..
anyway, once I got past the guard, i was met very briefly by the VP of Sales who introduced me to John S. who is Director - Technical Services .. he was able to provide me some info, including that Noel Murdough used to work there with him.. John was kind enough to connect me with the Slant/Fin regional Sales Rep. Perry L. who is on his way over to my house now for an onsite meet & greet. Perry was kind enough to refer me to a few local contractors as well. While at the plant, I also met Stacey who is head of Sales & Marketing and who provided me with some brochures ..
all in all .. I had a short but productive visit at the plant (no free samples :-) ) .. and I really got a warm and fuzzy about working with what seems to be a highly recommended and better yet, local, company for my boiler needs ..
FYI, I'm looking at the Intrepid TR-30 (Oil/Steam boiler) ...
Thanks
jpf
Thanks
jpf
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
Interested in Gas Wet Base also
Thanks jp for all this great info. I am interested in also upgrading to a gas wet base. My 20+ V7 Burnham is sucking up H20 like crazy. Got a leak at the water line into the firebox. It's working ok. Now I'm in southern Maine, have contacted slant fin and they have sent me a few names in the regional office to contact. Steamhead has recommended this boiler to me last year, I'm also interested in a dual fuel burner for this system. Any thoughts on a dual fuel burner? I am using your spreadsheet for my radiator vents, good job.
Thanks
MarkWeil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal0 -
waterline leaks
those leaks could indicate other problems, such as chlorides water contamination, water-softener salt too close, dry floor drain, or other problems with the system. see if you can narrow down the cause, so your new slantfin gives you 35 yrs!--nbc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
