cast iron or scotch marine
Steve_210
Member Posts: 647
another question. we are bidding a job where ascotch marine boiler is speced
we feel a burnham V905A would do the job just as good.
what are the plus features of a scotch marine
Is this
for a steam or hot-water system?All Steamed Up, Inc.
Consulting0 -
steam
sorry, its for steam0 -
comparsions
anybody have any comparsions0 -
Lots of comparisons
Scotch marine is lighter as a unit but one piece block to install. Tubes can be changed in a scotch marine. Water volume is lower in scotch marine. Efficiency should be higher as scotch marine is multi-pass. Water quality is important for both but more for scotch marine as it is steel.Cost is what you spend , value is what you get.
cell # 413-841-6726
thanks
thanks for the reply, is there any proublems using a drop header on a scotch marine boiler. (it would save digging a pit). I know they work well with cast iron and i cannot see the differance??0 -
I can not answer that.
Even with a Scottish father I have limited experience installing scotch marines. The ones Da worked on were Industrial level, Paper mills, Schools, and such. So Dropp headers were not needed as they had plenty of head room.Cost is what you spend , value is what you get.
cell # 413-841-6726
thanks
thanks charlie, i am atending dan;s class on wedensday night. hopefully he will have some answers. thanks again.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
