Vent question
ansky
ansky Member Posts: 41
I have a couple radiators in my 2nd floor bedrooms that are making the rooms too hot at night.  I completely closed the air vents on each radiator and they still get hot enough but not as hot as when they were completely open.  Are there any repercussions to closing off these air vents?  Each of them is at the end of a pipe so there is no worry about other radiators down the line getting hot.  Will these closed vents cause the pressure in my boiler to go up faster?  Right now my vaporstat is set at about 0.65 psi.
