steam pipe joint rusted solid
mel rowe
Member Posts: 324
Trying to replace the pipe that goes into the radiator inlet valve. The pipe is too short to match up with the height of the radiator. Haven't been able to get it to budge. Tried WD 40 and also used an extender on the end of my big pipe wrench. No luck. Is there something better than WD 40? Any other suggestions would also be appreciated. I'm afraid that if I just keep going as is, I am going to collapse the old pipe and create a big mess.
Give it some soaking time...
Try Liquid Wrench or PB Blaster. Hit it 4-6 times in the course of an hour and let it soak. Then get it with a wrench. If this doesn't work you might have to resort to heat. These fluids are light years better than WD40 for freeing rusted stuck items.There was an error rendering this rich post.
Stubborn pipe joint
Thanks very much, Scott. Sounds like just what I need.0 -
heat it with torch
if you can heat it up with torch the expansion will usually break it free specially if they used expando as pipe dope0 -
Torch
Heat it up and place a candle on the joint, it will wick the wax in, if you dont have a candle use a wax ring, both will work0 -
Heating the fitting
Hi -
Applying a lubricant several times is a good approach. If you go with heat, be sure to focus the heat on the fitting you're trying to remove and not the entire radiator. On those extra stuck fittings I've had good luck when another person taps lightly on the fitting I'm removing as I try to untwist it. I try to maximize leverage with the radiator in a position to support this, a leverage bar etc. Also, sometimes I can get it moving by tightening first then loosening once I've budged it. If the pipe does collapse, you can carefully remove it using a hack saw and chisel (saw several pieces of the fitting (careful not to bunge the threads), then chisel the pieces apart. Twisting the fitting out is of course the least time consuming and risky). I hope this goes well!
Gwen Healy - Radiator RangerThere was an error rendering this rich post.
- 50 Industry Classes
