corrosion from condensate
mor
mor Member Posts: 41
Has anyone actually encountered or seen a report of drain corrosion from untreated boiler condensate? Thanks.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    Yes
    It was old cast iron on its way out anyway. But I have seen it. I have also seen basement floors pitted from furnaces dripping on them instead of being pumped away.
    cell # 413-841-6726
  • TomS
    TomS Member Posts: 66
    Yes
    I have also seen the condensate make pit like tracks in a concrete floor.  The condensate seems to disolve the cement and what you see is a stone surface in a track below the level of the good cement. Very unsightly.   I am sure that this disolved cement must be beginning to plug something up.
    hot_rod Member Posts: 25,354
    copper fittings
    I have seen them pin-holed when used in low ph condensate drain applications.
    I too have seen concrete slabs erode where un-treated condensate runs across them. I suspect this low ph fluid would eat it's way through cast iron or steel traps also.
    Properly treated condesate, run through a neutralizer sized and maintained properly, shouldn't be a problem in any drain pipe material.
    hr
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,873
    You betcha....
    I've seen it take out cast iron i less than 10 years, copper in 2, and cement over time.
    The plumbing code states "Ye shall neutalizeth said acidic wasteth prior to dischargization into the sanitary or waste elimination sewerage system..." or something to that effect.
    Why do you ask?
    ME
  • mor
    Why do I ask
    I always treat the condensate, but it doesn't seem to be the common practice here. One reputable boiler company told me they don't consider it an issue. Still, I wouldn't leave a job unfinished like that. Thanks for the feedback. MB
  • Mark Eatherton
    Tell them to...
    R.T.D.C.! (Read The Danged Code!)
    Ask them how much they think it would cost to jack hammer up Mrs Smith's basement to replace the sanitary sewer that their non treated condensate destroyed...
    A good attorney would have a field day at their expense.
    Displacement costs, ground soil remediation, environmental mitigation, finished surface replacements, pain, suffering, and on and on...
    It is SO inexpensive to do it right the first time...
    ME
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    condensate
    Saw a boiler where the vent was run straight up without a drip tee.....you should see the insides of that boiler.........ugh!!!
