Heat load calc. for Macs
JamieP
Member Posts: 27
Does anyone make heatload applications for Macs????
Newer Macs
should be able to run most PC programs. Try using Bootcamp, or you may need to buy a PC emulator.
If you have an Apple store near you stop in. They are great at explaining how to make it work.0 -
But you need to buy Windows
Even though Macs can run Windows, they don't come with Windows. You'll need to buy a Windows CD. If you know anyone who is a student or a teacher, you might be able to get a copy of the CD for 90% off.
Maybe there's a calculator written in Java or something that would work for free on the Mac.There was an error rendering this rich post.
Windows not always necessary
I run HVAC-Calc for Windows on my (Intel) Mac using a helper application called Crossover
http://www.codeweavers.com/products/
($40 - I believe there is a free trial period)
many 'Windows' applications really don't need all the baggage of Windows, and will run fine in open source emulators based on 'Wine'.
http://davidbaumgold.com/tutorials/wine-mac/#will-it-work
I had some difficulty getting Wine set up, so the $40 to Codeweavers was well worth it.
YMMV - good luck!
Vbob0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
