identify steam radiator
Ed B.
Member Posts: 5
I am sizing a steam boiler for replacement and have found radiators that I am not familiar with - they are recessed cast iron - single row of tubes appr. 1" in diameter - the vents are located on the inside [between cabinet and radiation - you loosen a screw and lift out a small piece of blank tubes] - example:radiator is 23" high floor to top , tubes are 19" - radiator is 17" wide it has 9 tubes - I need to know a formula to determine square feet of steam required for this type of radiator.
Thanks,Ed
Thanks,Ed
picture? brand markings?
a picture would really help .. brand markings would be even better.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Are they Arco convectors?
If so a search will bring up another post with the ratings.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
