rhidden radiators
Yosef Guttman
Member Posts: 11
I have a house with a few hidden radiators (the radiator is in the basement in a box and vented to the upstairs). On all of them there is a vent to the outside I assume for fresh air The problem is when the heat is off you get cold air blowing through the house. Can I just cut this vent to the outside and let it get air from the basement or was there a reason that this was important
thanx
Yosef guttman
thanx
Yosef guttman
they are called indirect radiators
i believe you are referring to "indirect radiators". Hopefully this alone will point you towards more information. I'm sure you will get other responses .. I'm not sure about removing that vent.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
you could..usually
they also pulled the return air from the room they were actually heating..but your answer is yes.gwgillplumbingandheating.com
Under floor air supply
I had the underfloor indirects in my last home. I sealed the outside ducts to stop the cold air and simply opened the door that was located in the bottom of the box. There was enough convection that the system worked fine, but without the cold air that was obvious when the system wasn't producing heat.0
