Lost fuel
bill_105
Member Posts: 428
First I read of some guy helping himself to, a extra in Maine.
Now, some guy gives back to the community,. At the exact same spot as Exxon Valdez, at Bligh reef, the money is flowing, along with tens thousand of gallons of Diesel.
The coast gaurd says was no holiday cheer on this one
Something is wrong.
Something is wrong.
Valdez
The Valdez hit that reef 20 years ago. Most remember it, but I would bet the tug operators were just babies at the time and have no memory of it. Seems that it should be marked better or a light beacon or something. Good that this is not the same scale as the Valdez, and these guys had no trace of alcohol. Had the reef bounced back from the orig tragedy?
TimJust a guy running some pipes.0 -
It bounced back
Prince William Sound came back to life. Mother nature has a way of doing that. Exxon's money was about .00001 of it! But it made everyone happy when the state was in dire need. Oil then was less than $20.
Yesterday's occurance is sick. Forget the light houses or beacons. Even twenty years ago the technology should have prevented it. Now here we are again. And at the exact same spot.
They stopped all cleanup. It was only Diesel. Key word there is ONLY.
Heads are gonna roll on this one. Check ADN.com0 -
bill....
Did you use to go by the handle of WEEZBO???
ME0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
