Panasonic heat pump
NEED HELP WITH A PANASONIC MINI SPLIT HEAT PUMP INDOOR FAN WILL
RUN FINE BUT THE OUTDOOR UNIT WILL RUN RUN FOR 5-10 MIN AND DROP OUT HAS ANYONE RUN INTO THIS OR CAN SOMEONE TELL ME WHERE TO START PLEASE
  • Empire_2
    Empire_2 Posts: 2,340
    edited December 2009
    Iram357?
    Just a thought,..... Think about the Q:?  You asked.....................  DO you have ANY information to aid us into aiding you?  Like Pressures, Supply and return temps,? or what is the mod &serial #.s etc... .  SO far you told everyone here basically nothing, except it's not working.  If you are a home owner, call a pro,... If you are a tec., Any and all info could help the people here help you.
    You could have a Ref. leak to...............Possibly ??????  I don't know.  Information is a must.  DOn't mean to sound crude, but help us help you:-)
    Mike T.
