Panasonic heat pump
lram357
Member Posts: 2
NEED HELP WITH A PANASONIC MINI SPLIT HEAT PUMP INDOOR FAN WILL
RUN FINE BUT THE OUTDOOR UNIT WILL RUN RUN FOR 5-10 MIN AND DROP OUT HAS ANYONE RUN INTO THIS OR CAN SOMEONE TELL ME WHERE TO START PLEASE
Iram357?
Just a thought,..... Think about the Q:? You asked..................... DO you have ANY information to aid us into aiding you? Like Pressures, Supply and return temps,? or what is the mod &serial #.s etc... . SO far you told everyone here basically nothing, except it's not working. If you are a home owner, call a pro,... If you are a tec., Any and all info could help the people here help you.
You could have a Ref. leak to...............Possibly ?????? I don't know. Information is a must. DOn't mean to sound crude, but help us help you:-)
Mike T.0
