I NEED HELP WITH MY THERMOSTAT AND HEATING UNIT
Lily
Member Posts: 3
I have no idea what kind of heating unit this is, so i am posting pics. I have changed the old thermostat with the new hunter one, i connected all the wires with the exception of the blue one which doesnt have a name and i dont know what it is for. the hunter worked all summer (Az) and now that it is winter-y the heat doesnt work, so i put on the old one by memory, and now heat works but with super low airflow, nothing like before. I dont know what to do, i wish my hunter worked, if i have done something wrong please let me know how i can try and fix it. i would like to have the hunter working with heat and cool, if it is not compatible, please help me fix the airflow so that my heating and cooling can work fine with the old thermostat.
Thank you!!!!!
Lily
Thank you!!!!!
Lily
try
Try moving the white wire you have on the B to W and stand back. J/k The hunter IMO isn't a good thermostat. With your pics, it really looks like you need a service call for some maintenance. The outside coil looks very dirty. Maybe schedule a service call and let them check out your system before doing anything to be safe0 -
so?
so should i move the white wire from B to W ??
Also when heater works the big fan outside doesn't work. i don't know if that is normal or not?0 -
also wires labels are:
Y1YAir Conditioning processor- yellow
W/B - H - heating- white
RC -/VC - 24 volt cool- red
G/F-Fan-green
Blue - who knows?!
Can someone check and make sure i got the thermostat connected right?0 -
Seek professional advice....
If it is not wired correctly, you could do some serious damage to some expensive components.
THey really shouldn't sell some things to homeowners a Homers Despot...
ME0 -
get a pro for heat pump t-stat
get a pro to wire the t-stat properly. heat pumps work with a reversing valve that has to be wired according to the manufacturer's spec of powered for heat or powered for cool. also, wire colors are only useful if you refer to both ends - what matters is that each wire has a function which is independent of its color.0
