If our community has helped you, please consider making a contribution to support this website.  Thanks!
heatmaker
                    have heatmaker boiler/waterheater when temp falls fast boiler wont come on unless you run hot water no out side cotroll,has set back thermo. after running hot water boiler runs fine
            The SPDT
domestic hot water switch needs replaced.0 -
            Tim is correct
The part is actually called a low limit switch and is part # 2400-016 and Laars carries the part. It's very easy to replace, just pay attention to the color coded wires when you disconnect. The clip can be tricky, it's good to add a dab of thermal paste too.0 -
            heatmaker
Before you get the new one push the one you have now down as far as you can towards the tank and wrap insulation around it. Also make sure there is no air in the top of the tank with the coil in it,0 -
            Heatmaker
My favorite tool on a heatmaker is a sazall when i cut them out.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
