Water coming out of newly replaced vent
2»
  • Call Boilerpro
    and let us know the outcome.  I'm mesmerized.
    That radiator sounds permanently waterlogged (corroded and blocked air vent tapping?).  Either that or there is a dip or corrosion in the piping near the radiator; accumulates water that gets carried into the radiator when steaming.
  • blowing down
    there are 2 types of "blowing down", both done while the boiler is firing. the first and most important is blowing down the LWCO. the valve must be opened and water allowed out into a bucket until it runs clear, while verifying that the burner cuts off. that operation will flush out any sludge buildup in the float chamber of the LWCO which would prevent it from cutting off the burner when the waterline gets low. this should be done weekly, and only about a gallon is emptied out.
    the second operation is to open the main boiler drain and let the sediment at the bottom of the boiler be washed out. this probably will use 3 gallons of water, before it runs somewhat clear.
    neither operation is a substitute for the other, and will not clean the water--only remove solids at the bottom. only skimming, the controlled blowing off the waterline surface of oily residue will do that. if chemicals have been put into the water, better repeat these steps more frequently.--nbc
  • FJL
    FJL Member Posts: 354
    Thanks . . .
    for the clarification.  I've been doing the former, but not the latter.  Will doing the LWCO blow-down while the boiler is off clean out the LWCO as effectively as when the boiler is firing?  I understand that doing it while it is firing is necessary to confirm that the LWCO turns off the burners when the water get low, but does it clean out the LWCO as well when cold?
  • juliachicago
    juliachicago Member Posts: 22
    mesmerized
    i'm glad you're intrigued! i'm waiting until the new year to get this looked at, so busy. but i'll let you know what boilerpro finds, assuming he can come look at it.
    if case this makes any difference for the troubleshooting, the sloshing doesn't start until about 3/4 of the radiator is hot. and it stops immediately after the vent (spits some drops and) closes.
  • ansky
    ansky Member Posts: 41
    How do you blow down LWCO?
    How do you blow down the LWCO?  I'm new to steam, and the only thing I was told to do weekly is open the valve at the bottom of the boiler and let the water drain until it runs clear.  Then I add more water to make it return to the correct level.  So should I be doing this when the boiler is firing?  I have always done it when the boiler was off.  And I also notice that even after doing this there is still rust at the bottom of the glass tube.
